Tablets & eReaders Logo
Adriana Wallace Posted on Dec 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Nextbook's volume is stuck on full blast. I already turned it off several times but it is still stuck. What do I do?
Steve Garthe
Level 2:
New Friend:
  • Expert 78 Answers
  • Posted on Dec 30, 2014
Steve Garthe
Expert
Level 2:
New Friend:
Answers
78
Questions
Helped
11291
Points
199
Try resetting the nextbook to factory default. This may clear up your issue.
1helpful
Hw to get safe mode off a Nextbook tablet
To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the tablet is off, Touch and Hold the "Power" key again to restart.
The tablet should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
If that doesn't work try this...
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
I have a NextBook Ares 8 Tablet. Why does it take 12+ hours to recharge?
(this is all i could find on the internet so this is not to say it will help you but try it and see what happens).........PRess the power button and the volume down button at the same time and hold until the unit restarts... it resets the charging cycle and the note will charge reasonably quick from then on... I do this on occasion when my battery seems to charge slow.
plus some people are saying get a new charger.
How can I do a factory reset on my nextbook 7
Simple video on how to hard reset Nextbook Android Tablet. Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe data navigating with the volume buttons and then to wipe data.20 Aug 2013
Nextbook Android Tablet Hard Reset - YouTube
https://www.youtube.com/watch?v=TM-Ir-stVL8 https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=How+can+I+do+a+factory+reset+on+my+nextbook+7
NEXTBOOK 8 ,WITH WINDOWS 8.1, WENT INTO REPAIR LOOP, AND HOLDING POWER BUTTON AND VOLUME BUTTON WONT BRING UP MENU . NEED A FIX BAD
press power, press home button + volume at the same time a menu should appear in top corner , once that shows leave go of all three buttons then with volume press down and when you reach the heading you need press power . YOU DO THIS ONCE YOUR NEXTBOOK 8 IS TURN OFF ( make sure battery is in ).
When I try to refresh my tablet it won't work
You need to reset it by pressing the on button, and at the same time keep tapping the volume up several times till you see the little Andy Android come on and stop. This will reset your tablet. Good luck.
Cant hear volume too low
this could be a codec problem or video was record on low sound settings .try checking that your sound is up full right click on sound icon....open volume mixer make sure all slides are up full.
hope this helps
Nextbook tablet resets upon full shutdown
The problem could be that you are pressing down the power button and the volume button at the same time when you shut down. That will cause an android tablet to reset itself. There may be an issue with the power shut off button.
My nextbook won't reset
Throw it out and get a new one they are really inexpensive now a days .not worth the time or the headache. Sorry but true.
My nextbook wont charge?
Did you shut your Nextbook tablet down completely? You press down on the right of the volume button and at the same time press down on the on and off button this should turn it off to restore the unit to charge it.
I have a nextbook 7P12 and it won't turn on. I have charged it as I thought the battery was flat. Now it won't turn on and I'm stuck as what to do. Anyone know how to fix it? Thanks
The Nextbook tablet can be turned on by pushing down the volume button and the power on and off button at the same time, hold down a few seconds and wait. It should turn on again. It always works for me.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
