Digiland tablet won't charge. Is there a way to fix it or is it just defective?
Depends upon exactly what's happening.
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
SOURCE: I order two DIGILAND TABLETS AND I NEED TO KNOW
go into setting look for wifi and turn it on !
