This can happen only if u have chosen diff. Paper sizes or Id manual feed is on. Do first of all turn off the manual feed option.
2. Try to choose same paper as your document.
3. Hard reset the printer by turning on by holding green button.
if its possible install the printer on another PC. if it prints god without problem than problem on your PC, follow this:
1. delete the device from "start-> control panel-> devices and printers (win7) or printers and fax (win xp) choice hp laserjet 1320 right click -> remove device. and delete driver software from control panel - > software " Than reinstall the software and turn on printer
2. try the new and the latest versions of drivers. you can search it in Internet pay attention to date of software
3. replace USB cable of printer sometimes it acts to work of printer, use original cable but no so long cable (1-1,5 metr)
4. if problem unsolved than the work to engineers,
recently we solved same problem on hp 2015, you must open covers of printer and access main board - formatter (where USB port exists), remove all wires and reinstall properly, if problem unsolved the formatter (look at the images) must be heated with special heating device. But its work of masters, don't try heat it if you are not specialist.
