Need to know it put on
Use a gear puller to remove it. To reinstall it put a little bit of grease on the shaft align key way on the shaft to slot on flywheel pushing it down on the shaft to get it started then use a block of wood on center of the flywheel over the shaft strike the block driving the flywheel on to the shaft till the flywheel is even with the outside edge of the shaft. Put your bolt back in the shaft use some thread locker sealant on bolt threads before you install it. Hope this helps you.
