If your Whirlpool WRF535SMBMOO refrigerator has an ice maker that starts and stops making ice, there could be a problem with the ice maker itself or with the water supply to the ice maker. Here are a few things you can try to fix the problem:
Make sure that the ice maker is turned on. The ice maker has an on/off switch or button that you may need to activate to start making ice.
Check the water supply line to make sure it is not kinked or clogged. The water supply line delivers water to the ice maker, and if it is blocked, the ice maker will not be able to make ice.
Check the water inlet valve to make sure it is open and functioning properly. The water inlet valve is responsible for controlling the flow of water to the ice maker, and if it is not working properly, the ice maker will not be able to make ice.
Check the ice maker for any visible damage or debris. If the ice maker is damaged or clogged with debris, it may not be functioning properly.
If the problem persists after trying these steps, it is possible that there is a problem with the ice maker itself. In this case, you may need to have the ice maker inspected by a technician to determine the cause of the issue.
First review this YouTube video about how to fix a current Whirlpool ice maker that does not make ice. Most are fixable. (The maker of the video, Repair Clinic, will work with you to find the exact part needed and sell you that part. Excellent company to work with. Whirlpool Freezer Won Make Ice Ice Maker Assembly W10190965
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Since you're already online, why not visit the ice machine manufacturer's Website and... indicator lights mean with regard to what part of the operational cycle the machine is in, .... that it's the right size and turns in the right direction, and make sure no other appliances .... What does the ice pattern on the evaporator look like?
2 screws at the front of Ice maker they are screwed to ceiling of freezer. remove and then pull IM to you. try the test button under the motor of the IM before you replace. just push it and wait. should start to cycle in a few seconds. if it cycles and fills with water your ok. then give about 2 hours to see if it dumps ice. make sure your freezer temp is set to -1 or your IM may not cycle. that is a samsung thing.
a few things, was the ice maker working before repair?? generally the ice maker need to "cool" before making ice, usually give 24 hrs to start producing ice. next perhaps the tech shut off water supply never turned back on??? bottom freezer, perhaps he had to remove the ice maker to remove the back wall of freezer and never reconnected wire harness to the back wall.
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice. If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
