I tried to push the power button and low volume button. And I tried to put my password in to try to lock it and it won't I tried over 100 times and nothings working
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
You supposed to push down the +volume button and the power button at the. Same time. Till you see the logo
Testimonial: "The logo never showed up."
