Cameras Logo
R
Robin Rosario Posted on Jan 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When recording a video zoomed in how do you get the camera to focus on the object ?
Samsung WB1100F . I have tried setting it to auto focus , I have tried making the background behind the object a different color so they would contrast, and nothing seems to be working.
Harrie
Level 3:
Top Expert:
  • Samsung Master 6,746 Answers
  • Posted on Jan 03, 2015
 Harrie
Samsung Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1283757
Points
83153
Focusing is one of the most difficult parts for every digital camera. Special on the end of the moon, and if the lights are low. Every camera needs sharp contrasting backgrounds and no distracting other high contrast objects in the foreground.
Be aware when you soon in to the end of the zoom range, you can't focus on close objects. Minimum focus distance can be a few meters.
It could be you switched to silence the focus noise, what can be bad for focusing.
See what the manual is telling you about zoom and focus:
When recording a video zoomed in how do you get th - 25351857-hjrjg0wfn424agkzp5z2rlvj-3-0.png
Read the manual again, and check what settings would be the best for you while shooting video with a long zoom setting.
Here is the manual:
http://downloadcenter.samsung.com/content/UM/201405/20140522111801989/WB1100F_UM_English.pdf
Can one override the auto setting and have manual control over this camera
http://www.techradar.com/us/reviews/cameras-and-camcorders/cameras/compact-cameras/samsung-wb1100f-1254077/review try looking at your manual there are a lot of settings, but it sounds like you might need to stick with the auto setting for now.
My samsung galaxy fit camera is always blurry when I want to take a picture, if I hold it about an inch away from the object it acts as a magnifier how do I reset it so it works as a camera and not a
Does the camera have auto zoom/focus? It could be all the way zoomed in, or have a focusing issue--look at your settings and make sure it's all set to normal or 0% zoom.
1helpful
FUJI F550 HAS PROBLEM WITH FOCUS WITH VIDEO MODE KEEPS HUNTING IN ZOOM BLUR MOST DISTRATING
because the focus is set to infinity it will try to search for something to focus on. try setting it to auto or Manuel focus on what you want to record.
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto focus.show the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Canon Powershot SX10 IS auto focus unreliable
I don't this its an error. I have used this Canon SX10 IS Camera for nearly a year now I haven't had this kind of problem.
Usually auto focus take few seconds to focus on object depending on distance and lighting. That might be the problem ?
I have problems focusing my f8000sd fuji camera when zooming in on small things.IIf I try to zoom right in on a butterfly for example,it will not focus and I can't use macro and get closer in case it flies...
Use spot metering & focus when taking pictures of an object.
Set your camera to highest Megapixel setting, Only use max. optical zoom on the subject (do not use digital zoom) .U dont need to get close to object as you can edit/zoom/crop the picture using any photo software program afterwards .
1helpful
Video noise
When in video camera mode, press menu, and change auto focus mode from c (continuous) to s (single). The noise you hear is the auto focus motor going back and forth, trying to find the object focus constantly.
You can use this only if the object is not changing the distance to the camera while recording.
SC-D363
hmmm, the only thing i can think of is to try the easy Q mode and see if it works ok , when it is in easy Q mode it puts the video camera at a default setting and you cant change any of the menu options until you take it out of easy Q.
hope this helps
2helpful
Picture still blurred on record mode
Your problem sounds like a focus problem. Could be that it's on manual focus and you're hitting the sweet spot only in full zoom? From the manual: 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button.  M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus.  Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again. Hope it works out, let us know!
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
