Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it. You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Sounds like the door latch is stuck or broken. There is a gear in the side of the latch that turns when it hits the striker bolt on the door frame. You can try taking a screwdriver and pushing on the gear to see if it will move. You can look at one of the other doors to see how it is supposed to work.
to open door with child lock activated, insert a plastic strip( i used from Milk bottle) from outside where the child lock is. Try to push plastic in such a way the child lock push from closed position to open position. Myself did it in 3 attempts and door was able to open from inside in megane fidji 51 reg.
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
