SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops
filling nothing happens. However sometimes it will go complete cycle
ans a noise can be heard on spin cycle even though it is not spinning.
As thoiugh the motor is not engaging with the cylinder
Was this helpful?
Yes
No
SOURCE: fisher and paykel washing machine stopped
If the light that stays on when beeping is 7th from the right then the machine has a pressure transducer which is out of range, the motor controller module (electronic) will need to be replaced.
SOURCE: Fisher and Paykel Pride MW511 does not spin. Three
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: Hi. I need some info on the fisher and paykel
Hi - I will need the product number found on the sticker in the rear of the machine - the controls has been changed so it needs to be programmed to a 5Kg machine.
I cant help you without that information as there are about 6 methods of doing this, the product number will tell me which is the correct way.
