I need a tranformer for a resolv 65a
Are you an experienced tech? In most cases (unless there is a defect in manufacturing) transformers are not a common cause for failure. If it blows the fuse disconnect the secondaries and see if it still blows the fuse. If it does then the transformer is likely the cause, if the fuse doesn't blow then the problem is elsewhere. If you have 120vac at the primary and nothing(or very low) at the secondary(s) then the transformer could also be at fault. If you have done this already and narrowed it down to the transformer, sorry I cannot help. I used service Samson but no longer am able to get parts. Good luck!
Testimonial: "Very helpful..I will test again.Not sure I used the proper procedure."
