Cameras Logo
s
sayan haldar Posted on Jan 05, 2015
A thin vertical line is shown while taking pictures on my canon a810. plz help
I am worried about dis problem .. plz help
  • Naor Gamliel
    Naor Gamliel Feb 11, 2015
    Hi sayan haldar, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    does it shows only on the screen of the camera, or also when you view this images on the computer?
3 Related Answers
t00nz
CameraR
  • 4738 Answers
  • Posted on Feb 16, 2008
SOURCE: vertical lines on canon a95
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Anonymous
  • 477 Answers
  • Posted on May 28, 2008
Go to www.digitalcamrepair.com then click on the self diagnosis page. for your answer to your question.
Anonymous
  • 214 Answers
  • Posted on May 24, 2011
SOURCE: All my recent pictures taken
Hi if you also see the vertical line from computer, then your camera has defective ccd unit or main image control pcb defective. Most of case ccd problem are common and main. your local repair shop would charge around $45 to 135 depend on what they want to charge. Thanks and best regard!
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 • Cameras
4helpful
3answers
My television has no picture just one thin line in the center. Does anyone have any suggestions as to what is wrong?
You have a problem in vertical deviation in your television.It's need to be repaired by specialist.
9helpful
3answers
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
1helpful
Vertical lines on canon a95
2answers
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
It is due to immense use of your laptop. So dont worry, off it for some time and on it again. It will not come. It is the same problem i m facing with my laptop. All the best.
Canon A520 Vertical line appear on images
This appears to be a failing component possibly the CCD. It may be possible to replace the camera if this is the case An offer to repair however will be almost the price of buying the next camera. Contact the Canon support website.
Orion TV model TV_798 sl (thin line no picture)
problem is with the vertical output circuit. take it to a repair shop and have them fix it.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
