The 90 degree and shirt button flash together. What does this mean? The machine is full of water and I have tried draining/spinning and two further programmes and these two lights still appear. Upon research peoples posts keep saying to drain or check the filter but as this is integrated I don't have a filter. Any advice would be sincerely appreciated.
SOURCE: Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
SOURCE: Series 110 (old) Kenmore washer does not drain...
The drain pump may be clogged. I had the same problem and found a bunch of polyester fiber fill from a comforter my wife washed clogging up the water pump. Once cleared, it worked fine.
SOURCE: LG WD 8013F drains then won't spin
please rate my suggestion...
SOURCE: whirlpool awo 3751/5 will not spin
There is a locking coupler on the Whirlpool washing machines that locks when it kicks into spinning cycle. I am guessing here, but if you try and run it without any clothes in it, it will probably spin. It will be slow starting, but it will probably spin.
The coupler is located down by the motor and is three pieces. They made it out of plastic, and while it typically holds up very well, they do break. I will try to look up the part # you need to fix it. (assuming this is your problem)
Thank you for contacting www.Fixya.com
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
