I have hold the sleep and home button pressed for a while and the the screen turns black and if i put it in the charger or press the sleep button it begins again , and after blinking a long time the logo stops and the screen turns black and i let it charge and the charge sign comes on but if i turn it on i t begins blinking again so ??
Hi, This is probably too late but I really hope this can help you or others.
Firstly, we need to know what cause the Red Screen Issue:
A. Your iPhone Device Has A Hardware Problem
B. Your iPhone device has been jailbroken
C. Your iPhone device has a failed software update
Secondly, Here are some common solutions to fix Red Screen of ***** Issue:
A. Perform A Soft Restart on Your iPhone Device
B. Perform A Force Restart on Your iPhone Device
C. Restore Your iPhone's Default Factory Settings
D. Bring Your iPhone into DFU Mode
E. Update Your iPhone to The Latest Software
Thirdly, If the common solutions could not solve your problem. You can try an data recovery software - FoneDog toolkit.
Step 1: Download, install and launch FoneDog Toolkit.
Step 2: Proceed to System Recovery.
Step 3: Review Reminders before The Recovery Process.
Step 4: Download The Firmware.
Step 5: Downloading and Repairing
Step 6: Repair is Complete
More Information you can see: Ways to Fix Red Screen Issue in iPhone Device
The red screen issue in iPhone devices is truly a bothering issue to have since it can stop you from being productive in using the phone or making it fully functional. Through the common solutions we have shared above for fixing such issue, as well as the help of FoneDog toolkit, we hope that the red screen issue in your iPhone has now been fixed.
Hope it can help you!
iOS System Recovery Guide How to Fix with Various iOS System Issues
SOURCE: Can't power up or off.
I had this same problem last night. Today I popped out the MicroSD card and the phone came right back to normal. I was able to put the MicroSD card back in without having any troubles. So if you're using a MicroSD card, maybe this will help.
SOURCE: hanged iphone. 5sec solution didnt work
My iphone got hang after I change the wallpaper and everything is dissappeard.but its still ringing when somebody call me but I can't see and heard it.please help me what to do.thank you
josofine
SOURCE: my iphone wont go past the apple logo
hi juli this is glady even i faced the same prob in my i phone to so download a new firmware from apple site nd then switch off ur cell while conectd to ur pc then switch on through ur apple pc suite upgrde ur phone through the i tunes o give the path nd see or better to go to youtube for more crystal clear info bye
SOURCE: my Iphone 3g doesnt turn on.. I only get the apple
If you just see an apple logo or your phone does not turn on, there is
a software problem and you will need to restore your iPhone. I didn't
want to hear it, because now I had to redo everything; but it's the
only solution.
Put your iPhone into recovery mode.
To put your iPhone in recovery mode:
Step 1: Plug in your iPhone to your computer, make sure your sound is turned on and not muted.
Step 2: Hold the top corner button for two seconds. You should hear a sound.
Step 3: Now, still holding the top power button, immediately press the
home button and hold both buttons for 10 seconds. You should hear
another sound from your computer.
Step 4: Release the power button but *continue holding the home button*, for another 30 seconds.
Step 5: Meanwhile, continue holding the Home button and open iTunes.
Wait for it to tell you that it’s in restore mode. You should also hear
a third sound from your computer during this time.
Step
6: Click on your iPhone in iTunes. It should say it's in recovery mode
and need to be restored. Step 7: Click OK and restore it.
Now you will need to re-jailbreak it, and restore your backup, and also put your music back in.
Good Luck!
3ONO
Email : [email protected]
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Unlock:
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset the phone:
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
