Question about Maytag 20 cu. ft. Upright Freezer MQU2056B
When compressor comes on, the freezer makes a knocking sound. Is compressor going out?
Cleaned and vacuumed back open side- This freezer is about 7 years old. Worried that I will be away, and freezer will go out.
  • Joan Simon Jan 06, 2015
    Is working fine, other than the noise1
    Top Expert:
  • Maytag Master
  • 12,962 Answers
One of the springs that supports compressor motor inside housing is weak. When compressor turns on the motor torques up against the side of the housing. That explains the knock on startup.
The motor is still good but there is no way to replace the bad spring.
So you can just tolerate the start up knock. Motor has plenty of life in it still.
You can also think about tilting the compressor motor in its mounting in the direction opposite of where it is hitting so that the tilt helps the weak spring and there may be no startup knocking. U have nada to lose - try it!
Posted on Nov 26, 2015
    Director Badge:
    Uploaded 100 video answers.
  • Maytag Master
  • 504 Answers
Yes, looks like compressor needs to be replaced.
  • 906 Answers
Check the rubber mounts on the compressor
Posted on Jan 06, 2015
Anonymous
SOURCE:
New freezer is very noisy. Any tips?
If it sounds like it's knocking most likely it's the compressor possibility of faulty bearings, If it sounds like it's having a knocking sound with a rattling/ajar vibration when the compressor knocks off or on it's a sign of a new product/times lol!!! My mother has a GE fridgerator that she had when she first got married never gave my parent any trouble until the pull door handle lock broke which hazardous too children back in the forties and fifties :-( Good luck with your product and consult your product manufacturing retailer.
Mar 02, 2016 | Freezers
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
Jan 19, 2014 | GE 7 cu. ft. Chest Freezer FCM7DR
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
Freezer is making a loud noise, assume when compressor is on. Pretty much as soon as the door is opened, the noise begins. Things are still frozen inside.
inside the compressor body there are springs which sometimes break and allow the
motor to knock against the outer enclosure. There is no fix for this as the system is
sealed, short of replacing the compressor. Not a problem with operation, but quite
distracting.
On another note, if the freezer compartment is beginning to freeze up or the fan
blade was installed too far back on the shaft, this could also cause noise.
(it will only make the sound in the freezer compartment when the fan is running
if this is the case). Hope this helps.
Apr 28, 2011 | Woods Freezers
I cleaned and defrosted my stand up freezer and you can here it call to go on (clicking noise) but does not come on
Good day,
The clicking you hear is the compressor trying to start and cannot.
It could be caused by the start components mounted on the side of the compressor.
They can be removed and tested. There are 2 or 3 components.
The start relay, the start/run capacitor(some models only) and the overload protector(which makes that clicking sound you hear).
Take the parts to an appliance parts house. They are usually more than happy to test them for you.
If they test o.k. then your compressor failed. A very pricey repair done only by a pro. However.....
If your machine is under 5 years of age do nothing. Call your selling dealer. A new compressor would be free.
You would have to pay for start components but that would maintain the balance of the warranty on the compressor.
Nov 03, 2009 | Kenmore Freezers
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
LOAD CLICKING SOUND WHEN PLUGED IN TO ELECTRIC
did you just get the freezer or move it recently? this unit doesnt have any fans so I'm thinking the compressor is somehow out of place and when you plug it in the compressor is hitting its steel shell from the inside. remove the compartment cover on the side then plug the freezer in and see if the compressor is making the noise..
Jan 22, 2009 | Freezers
13.7 cu.ft mdel 970-242520
7 minutes on and 15 minutes off sounds like a good cycle time.
May 15, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Fridge and Freezer running, but not getting cold.
make sure your fans are working. one is in freezer section,the other at back by your compressor.
Jan 06, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Maytag 20 cu. ft. Upright Freezer MQU2056B Logo
190 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
Ismael Rodriguez...
Dennis Boxerman
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
