Removed panel and foam insulation covered in ice
Even if the unit if issue free, this older design is still suseptable to moisture intrusion behind the inner liner. If your ice is below or around where the fointain area is, than you may be leaking water from the fountain behind the outer door shell. Since your outer door and inner liner are no longer avail, the best suggestion is to turn the entire fridge off, and let everything completely dry before re assembly. Once insulation gets imbedded with moisture and freezes, the insulation factor diminishes. Although your outer door insulation should be the newer style semi solid foamed in style, so moisture intrusion will not be any deeper than an inch or so. If the fountain heater has failed around the dispenser, you attract moisture to that area too. Pleazer Appliance...
