Televison & Video Logo
Carl Jacka Posted on Jan 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a WS-55907 Mitsubishi Tv. I seeing curved blue and other lines on the bottom 25 percent of the screen. It distorts the color and makes it hard to read the ESPN news line on the bottom. Now I am getting a white haze added to the screen after about one minute of watching the TV and at times I lose the entire picture. What could be wrong with this TV and is it worth repairing?
Silas Lawrence
Level 3:
  • Master 906 Answers
  • Posted on Jan 06, 2015
Silas Lawrence
Master
Level 3:
Answers
906
Questions
Helped
181749
Points
2158
It sounds like the picture or screen is on the fritz. some are worth fixing. you are prolly looking a $700.00 or more to fix it.
  • Carl Jacka Jan 06, 2015
    I tried to adjust the convergence but the lines where bowed on the bottom portion and I could never get them to align. If it is jet the convergence curicuit boards how much would it cost to have a repairman fix it. I am wondering if it is worth repairing or just bite the bullet and buy a new TV.
4 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Oct 04, 2007
SOURCE: Mitsubishi ws-55907 rear projection tv
Substitute 2HDW PCB as a good first test.
Anonymous
  • 1030 Answers
  • Posted on Dec 07, 2007
SOURCE: RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Anonymous
  • 1030 Answers
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Anonymous
  • 19 Answers
  • Posted on May 26, 2009
SOURCE: distorted picture on a mitsubishi ws-55613 tv
hi!! you tv need be replaced regulator 9v ic, in signal board,this sufermount 3 pins ic are located in top view ,rigth bottom side.
part # BA09
location # IC9C25.
100 % THAT FIX YOU TV.
Mitsubishi 65 in has greenish blue coloring mainly at bottom of screen any idea's?
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
1helpful
Top of picture has distorted curve
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Distorted picture on screen
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Ws-55907
Yes, if it was fine before moving to downstairs, means it has lose connections or cold solder joints, especially on convergence ICs pins, please re-solder convergence ICs having mark like STK xxx
Regards,
2helpful
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
