Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
depending on the model, a broken belt is a good possibility. if you hear the motor going, but the bowl isnt moving, that is a sign of a broken belt, it is also possible the motor has failed.
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Your machine has multiple issues. First, the obvious: are the water lines turned on? When you try to fill it with water, can you hear the water valve humming? Try different temperatures, too. If it lets one temp in, but not the other, you need a water valve. If it doesn't hum at all, you could have a problem with the pressure switch or the timer.
The motor humming is the issue that worries me. Try removing the belt from the motor pulley. If the motor turns now, it's a transmission problem. If it won't agitate (you'll have to satisfy the pressure switch first) or spin at all, your transmission could be locked up. I've had limited success by pulling on the belt (hard) in both directions. This has only worked once to unjam the transmission.
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Open machine's rear panel and remove belt.
Check if motor spins (when it should, as per cycle stage).
If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it.
In case motor doesn't spin- Check with multi-meter if it get power.
If it get power - The problem is with the motor.
Good luck !!
