My printer doesnt operate but the green and ed light keeps on blinking. Trouble shooter said that parts inside of my printer are at the end of its service life
Most problem with printers are dirt inside. if you want to experiment, try opening the printer, usually held by snaps, if accomplished clean all contacts, cables ribbon wires, then reassemble. thats easier said than done.
If its the "parts are at end of service error" it usuallymeans ink pads are full but don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank, search ebay for "Epson Waste Ink Tank" it comes with reset program.
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, post a new comment to this effect and I will provide further help.
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them for sale very cheaply on E-Bay.
Epson has an interactive troubleshooting guide on their support site.
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section.
Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
