SOURCE: How to unlock nextbook
you will have to format the drive and install the windows back on it. Download a windows disk of pirateproxy.se and then use rufus to make a bootable image pop ur stik in a usb port restart the pc select first boot priority the stik not the hard drive you can do so by entering the bios ( pressing f2 or Del after pressing the power button ) and from there u go to boot and change the settings then save and exit and then ur good to go. hope this helped.
SOURCE: I cant unlock my daughters nextbook 712mc and reset option doesnt work what do i do
Try press the power button+volume up button,then select wipe/reset to factory.
Testimonial: "Ive tried that no matter how long or how i do it it wont do anything nothing comes up"
Are you able to connect other internet related applications through your WiFi.? If you have problem only in setting up your mail, either the receiving server may be temporarily down you may try setting up mail after sometime or your WiFi connection may be very slow. Check the connection speed from ScanMySpeed.com if it is slow, connect it with a better internet speed.
