I have a TH-PX60U that has a black line going down the front of the screen. It goes from black, then back to regular color. The black line keeps coming back. How can I get rid of the black line??
I've tried plugging in the yellow, white, red cables that plug in to the front bottom for the video audio, since the black line is in line. I was hoping it might go away.
Re: I have a TH-PX60U that has a black line going down...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
if it does not go all the way across the screen, may be the buffer board controlling that area. you can usually visually check for burnt/overheated parts, then replace that particular buffer. could also be X or Y sustain PCB depending on whether it is vertical or horizontal.Again, you might do a visual for burnt/overheated parts on the particular PCB & replace either parts or PCB.
Lastly , may be panel....not cost effective.
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
behind the front grille there is a wooden panel remove it and yo will see a small black epoxy box with 6 knobs sticking out from it.
with the color turned down all the way, look closely for r,g,b on the box beside each knob this denotes which knob is for which color.
you need to adjust the 1 marked g on the bottom row. this adjusts the green bias to the green tube. this will get rid off the whiteish lines. adjust this knob counterclockwise in a darkened room untill the color shows a black and white picture. adjust slowly as the set will be monitoring what you are doing and will adjust itself as you adjust. bring the green down just enough so you don't see anything, make sure that you don't see red or blue either, if you do also adjust untill you don't see any color. these adjustments should be done with the input set to a video input that has no signal coming in the set will show the input label and nothing else.
when you have the raster( screen ) all dark you can go to an input with a signal and make sure the image is black and white adjust the bias of the color that is too much so that it is black and white.
hope this makes sense to you. now turn the user color control back to where you want it.you are done. reassemble, enjoy
you might have to do this again in a few months as the control you have adjusted are dirty and can't be cleaned with a cleaner.
moving these controls cleans them but the color balance procedure would have to be completed after such movement of these contols and any quick movement would have to be done with the set turned off. a quick back and forth movement will do a better job cleaning the tracks inside that adjustmet block but will mean you will need to do the setup adjustment all over again in order to get the screen blank and the color to balance to black and white. the top 3 knobs are for focus of the individual colos only adjust if the red, green or blue isn't sharp, you can try these to see with out doing harm. finally if thebias is too low then th lifgt on the front of the set might blink at you and the auto alignment might get part way through and stop. if this happens you need to bring the bias adjustment back up slightly. adjust only the bias for the tube that has too much color to start with and if this happens you will know that the bias control you just adjusted is the 1 that needs to be adjusted slightly.
This problem is usually the ribbon cable connection at the top of the stripe. Reseat the cable first. The other possibility is the panel itself, but that is rare.
Keep us posted.
Dan
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Well let see if we can talk you thu "grayscaling " a set, first remove the speaker grill and the front cover to expose the screen/focus controls these will be six controls mounted on a plastic looking box, next turn the set on and get a good signal, Then from the custmer menu simpley go the the pix settings and turn the color all the way down, next use the screen controls to make the pix the best black and white you can. Next turn to a input that has no signal and the pix should be black, if there are small retrace lines simply turn down that color till it goes away , then back to a signal source that should still have a good black and white pix. Put everything back together and turn the color back up
