p
p w macnutt Posted on Jan 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to hook up a Marantz AV 8003 pre amp to a carver TFM 45 amplifier
Audio Service Clinic
Level 3:
  • Marantz Master 924 Answers
  • Posted on Jan 12, 2015
Marantz Master
Level 3:
Answers
924
Questions
Helped
351180
Points
1710
Marantz preamp out, to Carver amp(or line in). Have you tried this and had problems?
1 Related Answer
daytoncomput
Dayton Computer
  • 1640 Answers
  • Posted on Jan 04, 2015
SOURCE: Marantz AV 8003 preamp how do you hook up to a carver TFM 45 amplifier
Get a hold of the manuals for both systems. With that you can follow the directions and make the proper adjsutments.
How to hook a carver TFM 45 to a Marantz AV 8003 pre amp with Bose 901 speakers thank you very much
The output of the Marantz will go to the input of the Carver. The Bose EQ has to go into a Tape Monitor on the Marantz, or, you can connect the Marantz output to the Bose line in(not tape in). The line output of the Bose, to the Carver input.
Is there anything else I'm missing?
Carver TFM 35 amp what is the best way to hook it to a Marantz AV8003 pre app
No. You should use the line(or preamp output) to the Carver input. The only way you could use the tape output is if the Carver has input volume controls.
How to hook up a Marantz AZ8003 pre amp to a carver TFM 35 a.m.
Please see my last few comments on the same issue. If you can't find it, please let me know. BTW, Marantz does not show the AZ8003 to be a valid model.
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Where can i buy the little lights for the power display in a carver tfm 45 amplifier
HI...
Are you talking about meter lamps?
If so, contact bob at
www.vintage-electronics.cc
1helpful
Will the Marantz SR5004 work with the 901?
By itself, yes, in stereo for stereo analog source material only.
There's good news and bad news for the multichannel hopes you must be harboring.
The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to receive its Active Equalization (unless they, too, are 901's of the same version) and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on most (all?) AV receivers it disables any digital inputs.
The good news. I have a 7.1 setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Just draw the Front L and R analog pre-out from the Marantz to the Bose Active Equalizer then to the new amp. Adjust your speaker levels and enjoy.
2answers
Carver TFM 45 Repair manual
http://www.vintageaudiomanuals.com/
Write to [email protected]
Great guy.
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
