If it is on solid then you have a cover that is not closed try opening and closing all your covers. sometimes you need to use tape to hold them down if they wont stay closed on their own. If it is blinking then your developer unit is not communicating with the machine, this is the unit between the toner and the drum that is normally held in by one blue screw. pull it out and try using canned air to clean the electrical contacts on the back of it.
If you think this has to do with the battery power, you also should check the contacts in the battery compartment. If the are not shiny, you can try to clean them with a dry cloth or a cotton swap. Don't use sharp tools in or close by a camera.
Make sure the battery is inserted correct and the battery cover should be locked correct.
If the camera was not used for a long time, perhaps some contacts are oxidised. Those contacts you can switch, try to switch them several times. Open and close the battery door several times. Press the on of button several times. Put the battery in and remove it several times. And hope the contacts will work again.
First don't spent too much mont for repairs, because cameras are becoming cheaper and cheaper and in the mean while better and better.
You could try to open and close the cover several times and hope it starts working as it should. It has a switch connected to it, so the camera can see if the cover is open or closed. Now it is giving the wrong information. If the camera comes on, when the cover is open, that indicates the battery is still good, unless the it stops working within a short period of time.
The cover for the Ink cartirdges has a switch on it. Try opening the cover, then close it again, the switch may be jammed. Try repeating several times if it does not do anything. If it is still the same case, then someting from the inside of the printer has caused the failure.
If you have open and closed ALL covers then you probably have a bad door switch. Try turning the copier off (both power switches) and on again. If that doesn't work then you should call a qualified technician to look at it.
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly
installed
For the 'CH' check the covers and make
sure all covers are closed properly.
For the 'Blinking CH' take the dev.
Unit open and the reinstall unit properly.
Pls rate – thank you
had same problem. fixed this way: unplug power cable AND usb cable. Replug both in. physically remove both print cartidges. put them back in. this worked for me.
