your WI FI password should be on the back of your ROUTER . try typing in your Browser search box Make, model also state its a Wi Fi tablet click on search and on the page that appears . If you have a PC or Laptop use it to get the manual then you can read the instructions while setting up your tablet . Hope this helps .
More than likely it is a hardware failure or loose internal cable (eg. Motherboard to screen cable). You can try a factory reset, but doubtful it'll work.
I would try and contact the programmers that put these out and see what is going on. It may be that the game is not made to work with your specific unit.
Hi, Zeepads have an issue with powering on....when charging it is best to use the mains charging as it is more powerful....if you are sure they have been fully charged then try this:
Hold the power button down for about 2-3 minutes.
Listen for a small click.
Take finger off of power button and wait for about 30 seconds.
Hit the power button again.
Hopefully you should see the start up screen, post back with the results!
On your home screen tap the the app button,then tap the screen saver app. Tap Enable Screensaver to turn the screensaver mode on or off. Then remove the check to "service enable" check box.
