Cars & Trucks Logo
m
marklennox Posted on Jan 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hazard warning lights work fine but my indicaters wont flash
Not tried anything yet
dannydoesita
Level 3:
  • Cars & Trucks Master 778 Answers
  • Posted on Jan 10, 2015
dannydoesita
Level 3:
Answers
778
Questions
Helped
226494
Points
6375
This is a safety feature built into systems today. If one indicator goes out the other will stay on, and visa versa. Look into your cars fuse box for bad fuse at blinkers. GOOD LUCK FRIEND.
Mikey
Level 3:
Top Expert:
  • Cars & Trucks Master 6,903 Answers
 Mikey
Level 3:
Top Expert:
Answers
6903
Questions
5
Helped
1620629
Points
26101
Check the indicator switch at the steering wheel!
tip
Indicater or flasher problem on jeep cherokee 2003
If your having problems with your indicater or flashers on your vehicle then their are a couple of things that would be causing you problems.Now if when you press left or right turn the light flashes fast when turning one way but not the other then this indicates you have a blown bulb on the side that is causing it to flash faster so you need to press it to that side and have a look at the front and back bulbs and change the one thats not working.
If on the other hand your flasher/indicater works sometimes and not others then this is usually down to the flasher relay located in fuse box (see pictures below)
To find out if it is the relay and not the flasher control that you press to turn the indicator lights on is to try using the hazard warning light button press this and if this works every time then the chances are its the control and not the relay (see pictures below) but if it sometimes works and sometimes dont or if it dont work at all then this points towards the relay so changing this should then solve your problem
FLASHER REMOVAL
  1. Disconnect and isolate the battery negative lead.
  2. Remove the steering column opening cover from the instrument panel.
  3. Remove the combination flasher from the junction block
    Combination Flasher
  4. spacer.gif90ba789c.gifspacer.gifspacer.gifView Full Imagespacer.gif 1 - COMBINATION FLASHER 2 - JUNCTION BLOCK
Ispacer.gif2009-03-25_033953_wj005003.thumb.gifspacer.gifspacer.gifView Full Imagespacer.gifNSTALLATION
  1. replace the flasher relay into the possition you took the old one out of in junction block.
  2. make sure you line this up correctly to prevent damage being done to the pins when inserting it into the holder
  3. make sure that the flasher relay is inserted correctly and far enough make sure its seated flush the same as the other relay units.
  4. now all you need to do is re-fit the cover to the steering column
  5. Reconnect the battery negative cable.
TURN SIGNAL AND HAZARD WARNING SWITCH
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove the screw that secures the lower tilting steering column shroud to the steering column multi-function switch mounting housing Steering Column Shrouds Remove/Install
  3. disconnect the two halves of the tilting steering column shroud from each other and remove both halves from the steering column.
  4. Disconnect the wiring harness from the turn signal switch and make sure you remember how it comes out of the fitting to ensure you fit it back correctly as it was.
  5. Remove the two screws that secure the left multi-function switch to the multi-function switch mounting housing Left Multi-Function Switch Remove/Install
  6. Remove the left multi-function switch from the multi-function switch mounting housing.
INSTALLATION
  1. Position the left multi-function switch onto the multi-function switch mounting housing.
  2. Install and tighten the two screws that secure the left multi-function switch to the multi-function switch mounting housing. Tighten the screws to2.5 N·m (22 in. lbs.)
  3. re-fit the wiring harness to the switch.
  4. Position the lower tilting steering column shroud to the underside of the steering column.
  5. Instal land tighten the screw that secures the lower tilting steering column shroud to the multi-function switch mounting housing. Tighten the screw to 1.9 N·m (17 in. lbs.)
  6. Position the upper tilting column shroud over the steering column with the hazard warning switch button inserted through the hole in the upper surface of the shroud. Align the upper tilting steering column shroud to the lower shroud and snap the two shroud halves together.
  7. Reconnect the battery negative cable.
spacer.gif2009-03-25_033747_90b04f0f.thumb.gifspacer.gifspacer.gifView Full Imagespacer.gif
2answers
Turn signal
check the individual indicater bulbs are all working ,actually look at each one not just the dash indicater light ,if all ok try the hazard switch if same happens the indicator relay needs changing if not the light/indicator switch will need replacing i would think good luck
Hi wonderd if any one can help. i have a ford focus 2002 tddi estate the hazards arnt working but the indicaters are. i've changed the hazard switch for a new one and checked all the fuses in the
Look on the back of the fuse board ,for this you have to drop the fuse board as their are two fuses at the back and i know one is for the central locking ,the other ? Now when the hazard switch is disconnected the indicators shouldnt work but the only thing i can think of is the indicator unit is faulty ,do the hazards light the indicator lights up and they dont flash or is nothing happening?
Audi tt x reg - the key fob is not working. Additionally, the hazard warning lights intermittently come on when i the engine. The hazard warning lights do not stop flashing and i often have to try...
this can be a big problem so will start on easiest first. and try to repair as going, the passenger door the problem with this could be the solenoid for the door lock. and or the switches in the lock. driver door has the same but is the master door. ie if you open door from unlocking at pass door it will only open this door, drivers side will open all doors. flashing hazards this could be because the alarm is not completely turned off this could be because of the doors, mainly the drivers side. try to find the fault with the door lock and get back to me when you have found the fault. you will need a meter to check for volts and the switches, check them as lock unlock from the inside and the key to make sure they working. dpd spray should be able to clean them if you can spray into the lock and housing that is plastic. give a good flush out after its working wipe up the mess from the spray and mear grease on the lock moving parts.
Turn signal wont work on 2002 c320
The trafficator flash can that clicks and flashes the turn indicator lamps maybe faulty or the trafficator fuse is faulty.
To test the flasher press the hazard warning switch on and if the warning lights do not turn on then the fault is the trafficator can or the fuse is faulty.
1helpful
I have a 2002 audi tt, the indicators are not working but the hazard lights are still working
check the fuse sounds like that has blown as hazards work on a relay indicaters are off a fuse
2answers
Signal lights
its the multifunction switch gone bad
98 jeep grand cherokee's turn signal on the dash and the lights quit working...the hazard lights are fine.
Turn Signal Light and Hazard Lights have one separated accesory. For this component review the Page 8J-1 / Fig 2 in this document: ZJ-Secc-8J-Turn-Signals-and-Hazard-Warning-Flashes
Maybe can help you. Good luck.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
