Setting it to the "H" setting
Over time, Calcium will deposit on the tubes and containers which get in touch with water.
The calcium can also impact the function of the Heating elements in the percolator tube.
Try Decalcifying with Designated Products.
Usually, you do this by diluting the product, fill up the water reservoir, and cycle on the machine, without cofee of course,
Pour out the water. It will probably look troubled.
If the water does not start percolating, just let the water reservoir stand with the decalcification product for about 30 mins. don't leave it in overnight, because these products are slightly caustic to remove the Calcium, but it could damage parts if left in the machine overnight.
Repeat the process until the water starts running faster.
don't forget to rinse with regular water. 2 Cycles rinsing should suffice.
See manual for suggested products or just use 1/4 cup of Vinegar diluted with Water. .
I would repeat this process every month or so if you use your machine daily.
If this does not solve, try contacting cuisinart customer service at 1-800-726-0190
SOURCE: My cuisinart carafeless coffee maker is not working..
dear,
read this comment and you will get what u want .
or if any confusion, read its manual keenly.
regards,
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
SOURCE: Cuisinart DCC 1150: coffee is not hot enough
Using the 1-4 cup setting will help, but that model does not have an actual heating element in the plate - definitely not the right model for someone who likes very hot coffee.
