SOURCE: GAME FREEZE
Firstly let me just say that all audio visual units such as this, should come with lens cleaning utilities, as more often then not the laser eye is simply dirty.
SOURCE: system freezes
Firstly, just out of interest, in the Settings menu, do this if using HDMI: BD/DVD-->HDMI 1080p 24mhz...this will be set to 'Automatic'...change it to 'Off'. Now try to play your Blue Ray disk. If not, it seems that your blue ray system is overheating, and the system is not giving it enough cooling allowance. I had the same problem. I called Sony support UK up and explained to them that I had a "blue ray laser failure", and if your PS3 is in warrenty, they send a courier to your door and replace it for FREE. They take your old one off you. I got my new one within a week just.
SOURCE: My ps3 keeps freezing when I play games
PS3 is one of the most amazing gaming device but like other competitor
gaming devices (Xbox and Wii) It also has some problems like Freezing
up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up.
SOURCE: every game keeps freezing about 10ins into it
USE A DISC CLEANER DISC AND TRY OPENENING UR PS2 AND BLOWING IT OUT
SOURCE: i think my disk stops spinning after 10 mins
Change out the optical laser and servo motor or by a new rom drive for this unit at this point what is going on is the motor is giving out to soon due to a optical laser issue. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Hi martin widdicombe, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Im kind of stomped too. First I never hear of a 12 gb PS3, but my first idea is how much space is free? If you dont have enough space for the memory and cpu to operate that could be the problem. Delete a few saved game memory and try it. If it works then you need a bigger storage space. Good Luck!
