Question about Epic View 550 Treadmill
Tredmill works fine but won't show speed incline or calories (any of the blue LEDs) any help would be greatly appreciated.
CONSOLE HAS NOT LIGHTS
Can you change the illumination setting like in a car? The lights are most likely LEDs which dont just burn out. and are independent.
Apr 05, 2014 | Exercise & Fitness
Treadmill buttons not working
Here is a link to the manual pay close attention to page 16 this will tell you how to see if it is in fact in the demo mode and how to cancel it. Some thing to remember about the display is that it is a matrix with contacts going both horizontal and vertical if one is broken some buttons will work and other won't. You may want to remove the console and clean the ribbon cables.
Mar 18, 2014 | Exercise & Fitness
Nautilus NTR 800.6 Treadmill. I can go up on speed and incline but not back down?
please RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
Test the speed sensor, for open or faulty, clean it, and tight the connector very well. see the diagram
Happy New Year. God bless you
Jan 01, 2013 | Exercise & Fitness
I need to reset the control system, does anyone know how?
Is it an Icon product? Free motion, Proform, Reebok or something under thenIcon umbrella? If all else works good then it's the lower board that's fried the speed part of the controls. It would need to be replaced.
Jan 08, 2018 | Nordic Track NordicTrack T7 si Treadmill
How do you change the incline
Kind of hard without knowing what kind of tredmill you have, mine has several programs with preset incline and speeds, to reset them I need to press and hond the stop button, then kind of go thru each "program" I also have a manual button, which I find the easiest, when Im in manual program- I can press the + or- for incline or speed- sorry, thats all I have for you-
Feb 07, 2012 | Cadence Exercise & Fitness
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    Epic View 550 Treadmill Logo
    138 people viewed this question
    Top Epic Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Colin Stickland
    Colin Stickland
    Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
