Heat comes on, but doesn't dry clothes. water comiong out of the hose in back
When a dryer usually produces visable water from any part of it's self, the suggestion would be a completely restricted vent line. Such restrictions could be from nests from animals, excess lint, a dip in the vent hose causing lint and water to collect. Since the dryer is leaking water, it is heating and therefore creting steam in an effort to dry the cloths, with a clogged vent the steam has no where to escape to and thus condenses within the dryer and leaks out. The vent needs to be checked by a wualified vent servicing company from the back of the dryer to the point of exit of the home. Pleazer Appliance...
SOURCE: maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
SOURCE: no heat to dry clothes
The machine is probably doing exactly what it is supposed to do and failing safe because of a problem. This problem is usually the result of an overheat causing a thermal cutout to trip. While I don't know this machine specifically, you will probably find that there is a screw on bulge on the back of the machine that covers the fan and heater unit. (Unplug from the mains first!!) remove the panel (Usually about 6-8 screws) and inside you will find a heater element. Near to this you will find at least one thermal cutout, it will be a little metal disc set in plastic, about the size of a penny with 2 wires coming off it. There may be more than one of these, but typically, only one has a tiny hole in the back at the centre. If you push a paper clip or pin into the hole gently, you will hear a click as the metal disc in the cutout pops from a concave to a convex shape and re-sets the cutout.
Reassemble and the problem should be fixed. Now ask yourself why it tripped? Usually because:
Both these things will cause an overheat and the cutout will trip.
These things very seldom fail because of a fault, but if the unit keeps tripping the thermal cutout, the problem may be a real heater fault and you should look to change the heater element or get someone to change it for you if you are unsure.
SOURCE: The dryer will not heat up to dry clothes
youve probably got a bad heating element, also make sure air is blowing out back of dryer to the outside of house if its plugged it will cause element to break good luck
SOURCE: dryer drum rotates but no heat to dry the clothes.
burnt or loose power supply cord at the point it attaches to your dryer. also may have a clogged vent.
SOURCE: I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element
Often a dryer heating element burns out, but
doesn't trip the circuit breaker or blow a fuse. The heating element is
simply a long coil of special wire. You can check it for continuity with
an ohm meter. No continuity means the element is bad and you need to
replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to
the exhaust duct inside the back cover panel. The fuse--which is about
an inch long--is usually embedded in black resin and mounted in a white
plastic housing. If the fuse has blown, you need to replace it. (You
can't re-set it.)
Wiring
A common problem is for the main wiring connection
from the house, at the dryer, to burn and break its connection. Because
the dryer can still tumble with partial power, the connection may be
only partially defective. You may need to replace both the power cord to
the dryer and the terminal block inside the dryer that the wire is
attached to.
