Tablets & eReaders Logo
C
Catherine Coulton Posted on Jan 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hannspree SN1AT748 10.1 inch screen Tablet is not connecting to the internet. What can I do?
It says it has authentication problem. my Sky code is over the top of this. I have never been on the internet with this tablet. I have a desk top computer. I do not have any problems with that. Can someone help me please?
  • Robert Hunt Jan 14, 2015
    Hi Catherine Coulton, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Have you setup basic connection information in the wireless setup screen?
  • Catherine Coulton
    Catherine Coulton Jan 15, 2015
    Hi Robert Hunt., Thank you for answering me. I am not very good with technology I am self taught. I assume you mean where the tablet has picked up my Sky router wireless name, it has that but not the passcode, and I cannot see how to enter it.It is telling me authentication problem. I press this then get a box telling me signal strength excellent and security wpa/wpa2 psk. I press connect and get saved with security wpa/wpa2. Then it goes back to authentication problem. I cannot see where to put any information in.It is a Hannspree SN1AT748. Hope you understand all of this.
Robert Hunt
Level 2:
Sergeant:
Champion:
  • Expert 208 Answers
  • Posted on Jan 15, 2015
Robert Hunt
Expert
Level 2:
Sergeant:
Champion:
Answers
208
Questions
Helped
37252
Points
555
You should be able to find "WI-FI Connections", select it. Next, select the router from the list that will be displayed. Now, you should be prompted to enter the password. I assume you know the password to your router. If not, look on the router itself for the code. You may find different codes on the router, try each one until you find the one that works. Otherwise, look at your instructions for any clues. Good luck.
Wi-Fi states authentication problem but can't reconnect and it won't give me the chance to input password
delete/forget the wifi connection in the tablet. re do the wifi set up with the proper WEP/WPA password from the router.
How do I connect to my wifi
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
Cheers
Hannspree tablet
Try to factory reset your device. Please follow the steps on the video provided below.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Why won't my tablet turn on?
are you sure that you have recharged the battery fully ?? It could be some kinds of virus, try to remove all connections and extra cards and try to open it again
Why does my tablet keep saying authication problems when trying to connect to wifi and why did my wifi bar from top of screen dissappear
Make sure your wifi is turned on and check to see if you've entered the correct authentication key.. If so, check your wifi and make sure it's not blocking your device from access privileges.. This sometimes happens and you simply need to grant your device access again.. good luck with it...
7helpful
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Authenication problems
No I connect by Ethernet cable and still want connect
2answers
Error 7 when i try sky go movies
according to the sky help forums at http://helpforum.sky.com/t5/Using-Sky-Go/Sky-Go-Errors-5-7-amp-9-on-iPhone-iPad-amp-iPod-touch/td-p/208239/page/4
Try the following steps to resolve this issue:
  1. Locate the Sky Go app on your Mobile device.
  2. Hold down the icon until the app wobbles (You will see a White Circle with a Black Cross symbol, press on the cross to remove the app)
  3. You will then be asked to confirm you wish to delete the app - Press Delete the Sky Go App will then be removed
  4. Go back to the App Store and reinstall the Sky Go App. This can be found by searching for BSKYB
  5. Access the Sky Go app again and you should be able to view content after you sign back in using your Sky ID & password.
Hope this helps
Top Hannspree Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
