Have tried the reset option but this does not work.
This can happen if there's a dead short in a speaker wire or if you're using very low impedance loudspeakers at high volume for an extended length of time. If the protection light came on due to a speaker wire short, low impedance condition or a bad speaker, the receiver's power will need to be turned off to reset it. Before turning the power back on, all speaker wire connections should be checked for their integrity at the receiver side and at the speaker side. If the protection light goes on immediately after you turn on the receiver, disconnect the speaker wires at the receiver side and retest. If the receiver's protection light goes off, then there would still seem to be a problem with one channel's speaker wires or speakers. Connecting them one by one and retesting should allow you to find the problem speaker or connection.
Testimonial: "Thank you for your help. I have tried different speakers and speaker wires but the system just won't let me get any sound. The flashing light, on the volume knob (not as previously stated on the selector knob) will blink fast when the speakers are tuned on, slower if muted and no blinking if the speakers are turned off. Even with nothing connected the protection circuits are working the same way. I would have to conclude that a circuit board is at fault. Since there are no repair shops in the Cook Islands, purchasing a new receiver is about the only option as freight is very expensive."
SOURCE: amp keeps switching off
There is a problem with one or both of the audio amp circuits. The amp is going into a protect mode as to protect and save your speakers. Sorry but there is no simple fix. this will need to go to the shop to be diagnoised. Good Luck
SOURCE: No Sound in DTV/CBL mode
Ok... I'm still new to the HDMI input. But I'm going to take a shot in the dark on this one.
Please don't rate me poorly for this, by the way. I'd rather you don't rate me at all as I am not proposing a solution.
This is a guess. I'll be honest about that. So here goes... :P
I read through the manual a bit. (Click HERE for the manual.) I started thinking to myself about your situation...and noticed that you seem to be focused primarily on the receiver itself.
What about the Satellite receiver? Have you checked it to see if you might have to manually switch the audio output to your HDMI output? I know you have video and all, but many devices won't assume that you're switching BOTH the video AND the audio outputs. Sometimes you have to manually switch one or the other, depending on how you're connected.
I would check the SAT receiver to see if you have to switch the audio output to go out from the HDMI output on the SAT receiver.
It has always been my experience that when the speaker icons flash on the audio receiver and you're sending a digital signal to it, the receiver is in fact NOT receiving a signal...
...which obviously means that one is not being sent to it.
Please let me know what you come up with. Again, this was just a shot in the dark. But I am curious either way. :)
Let me know!
Cyryl
SOURCE: Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
SOURCE: marantz sr6001 amplifier flashing on standby continuously
hi there
check settings for this configuration ......if you have a subwoofer in the settings, for best overall results choose subwoofer yes, and set main/center/surrround to small....if no subwoofer set left/right speakers to large and small to center, if there is no loe frequency effect (lfe) going to the subwoofer it will go into standby....hope this hlps ....shia
SOURCE: Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
