SOURCE: HP officeject G55 prints the same page over and over
I understand that your HP G55 prints the same page again and again. * Restart Spooler: To resolve the issue, restart the spooler by following these steps: 1. Click Start, and then Control Panel. a. For Category View: 1. Click Performance and Maintenance. 2. Click Administrative tools. 3. Double-click Services. b. For Classic view: 1. Double-click Administrative Tools. 2. Double-click Services. 2. Locate print spooler on the list, right-click and choose Restart. A progress message will appear and the spooler should be clear. You should now be able to print or remove the printer driver as required.
SOURCE: Yellow won't print with old or new cartridge
Some ink jets are differant. Some have an Ink jet cartridge system that has the print head on the cartridge itself. Others use a seperate print head. When you pull out the ink cartridge is there another small unit below the cartridge that you can pull out? If so that is the print head and you will need to replace it. Also make sure that you have taken off the tape off of the air pilot hole on the ink cartridge so it can work properly. www.tonerovernight.com
SOURCE: HP 4600 Color Printer stays in "Initialize" Mode
If you are using a jetdirect network card it could be the cause of your problem. Pull the network card and restart the machine. Seen it a couple of times
SOURCE: how to print configuration page
Printing a self-test page
Method one: Print a self-test page from the All-in-One control panel
Method two: Print a self-test page from the computer
