Question about Microsoft Internet Explorer 8
Internet Explorer blocat cu (0xc0000005)
Windows XP Profesional
2 Suggested Answers
Anonymous
SOURCE:
fathitkf
Fathi Elmahdi
  • 1871 Answers
SOURCE: When I start Internet explorer...
scan system for viruses then here is my advice : Just go to www.microsoft.com and download internet explorer again and install it , then reboot your system . I'm sure that this will solve the problem . any way , why don't you try other internet communication softwares like ( firefox or google chrome) those both are great also . I advice you to have more than one internet communication software . I already have three just in case if one of them is corrupted . I have ( Internet explorer and firefox and google chrome ) . just try the idea and you'll be satisfied with the result .
If that didn't help then try to check system for errors . such as registry errors .
good luck .
rate if useful please !
Posted on Jan 30, 2010
0xc0000005 error
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem Stop Error 0Xc0000005 in Internet Explorer
"Access Violation (0Xc0000005 exception)" is a known problem with Internet Explorer 6.
When you try to open a web page in Internet Explorer 6 that has an opening HTML tag "<SPAN>" without a closing "</SPAN>" tag, this error can appear and render Internet Explorer nonfunctional.
Microsoft provides a hotfix to update versions of Internet Explorer 6 affected by this problem.
Visit the Microsoft Hotfix Request page for this error (see Below).
http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=832823&kbln=en-us
Check the box next to "Internet Explorer 6.0."
Enter your email address in both boxes.
Microsoft will email the hotfix to this address, so be sure it is a valid email that you can access from the computer at which you are experiencing the error.
Type the letters you see in the box.
This confirms you are a human and not an automated bot.
Click "Request Hotfix."
Check your email for a message from Microsoft.
Click the download link in that email.
Save the .EXE download to your computer.
Double-click on the downloaded .EXE file when the download completes.
Follow the onscreen wizard instructions to complete the hotfix installation process.
Aug 09, 2013 | Gateway GT4022 PC Desktop
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
A ramas cursorul blocat da ii introduc un mouse merge sageata dar daca scot mouse-ul nu mai merge. s-a blocat dintr-o data, era pus pe pauza la un film cand sa luat lumina si sa intrerupt internetul pt ca...
driverul de touchpad a fost corupt. dezinstaleaza-l din Control Panel > Programs si descarca unul nou de pe situl producatorului laptopului tau. cind descarcarea s-a terminat instaleaza-l.
Feb 28, 2011 | Computers & Internet
I keep getting this error about a line and character not being In the library? internet explorer
Hi poltergist22
Normally the easiest thing to do with internet explorer is to install it again.
Try to first install it over the old Internet explorer and see if it works.
If not:
try to uninstall it first, then restart the computer and then reinstall the software (IE8). For this action I advice you to have another browser in case internet explorer should not work, at least to have Firefox portable.
Internet Explorer 8 link :
http://www.microsoft.com/windows/internet-explorer/default.aspx
Note: you can chance the default language to your language in the upper right corner.
Firefox portable link:
http://portableapps.com/apps/internet/firefox_portable
If this not work, please chek your firewall that is not blocating your Internet explorer 8 and your antivirus has not quarantine some files of your internet explorer 8
You can also try to chek your Internet Explorer 8 in default settings without any software apply: got to Start- All programs- accessories- sistem......- Internet Explorer (without accessories).
If this browser works, that means that it is something wrong with your extra programs you have installed on Internet explorer 8
Hope that helps
Have a nice day
Please rate my answer
Sep 13, 2009 | Microsoft Internet Explorer 8
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
/NOEXECUTE
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Oct 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Intellinav.exe application error
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Scoee Scoffer
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
