Question about Hoover AAA160 Front Load Washer
My hoover vt d2 washing machine, when on the spin cycle shows 7 minutes duration but goes on for 14 minutes, what could be the reason for this?
    Master:
  • 413 Answers
Probably a defective timer. Call repairman to replace.
Posted on Jan 16, 2015
  • Derek Drayton
    Derek Drayton Jan 19, 2015
    thank you, repair man has been and I have also phoned hoover, both say the same this is how the machine is ment to work on the spin cycle even if its a half load or full load it runs for 14 minutes.
6ya staff
SOURCE:
My Hoover 750L starts its spin cycle but when goes to a really high spin it makes a noise.
Check your mounts and support springs---one of them maybe broke or loose---since you haven't described the noise this is the best i can come up with. GL
Sep 18, 2017 | Hoover Washing Machines
Hoover 2305L goes through all cycles well.does not spin fast enough to dry clothes.
how old is the 7 kg washing machine
should be direct drive to the drum not a belt drive
the motor could be wearing out
are you over loading
May 11, 2016 | Hoover Washing Machines
The 7kg hoover will wash then stop agitating
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
Oct 08, 2008 | Hoover HTC243 Top Load Washer
Hoover 200m Top Loading Machine Spin Cycle Too short
no not normal many different things can be wrong need more info
May 08, 2008 | Hoover HTC243 Top Load Washer
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Hoover AAA160 Front Load Washer Logo
94 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
