Toys Logo
Sharon Pike Posted on Jan 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I record on the Sweet Messages Photobug
JEM
Level 3:
  • Master 406 Answers
  • Posted on Jan 18, 2015
 JEM
Master
Level 3:
Answers
406
Questions
Helped
149168
Points
2858
The instructions are slim. Check the link below from Tomy. Apparently there is a button at the top of each page, that you press to record and release to play. Hmmm?
Sweet Messages Photo Bug
Can two d3200 recorders connected and record 24 tracks simultaneously
I will assume you want to sync the two as one. I have one of these sitting in a closet. The 3200 will record 12 tracks at a time if I remember correctly. I believe the Korg will sync to Midi Time code. I just wonder if the midi implementation allows for start and stop code. Anyway, I found this information:
x2. MIDI messages used by the D3200 Note On (Note, velocity), aftertouch, pitch-bend:
The D3200 uses these messages to control effects.
Program change:
The D3200 uses these messages to switch scenes.
Control change:
The D3200 uses these messages to control mixer and
effect parameters.
MMC (MIDI Machine Control):
MMC messages can be transmitted from the D3200 to control an external MMC-compatible sequencer or recorder. MMC messages received from an external sequencer or recorder can be used to control the D3200.
MTC (MIDI Time Code):
The D3200 can transmit or receive MTC messages to
synchronize with an external sequencer or recorder.
MIDI Clock:
The D3200 can transmit MIDI Clock. It can also receive MIDI Clock if you have selected MIDI Clock for the tempo track and are recording the tempo track.
Jul 04, 2019 • Korg Music
tip
How to Transfer Text Messages from iPhone 6 (Plus) to Computer
Text messages, records some of the most vital and sweet memories of our life. However, it is not an uncommon occurrence that our iPhone text messages can get lost due to various of reasons, like mistaken deletion, iOS update, jailbreak, and even the device damage or device get stolen. Don't rely on iCloud to keep all of your iPhone text messages, the most safe way is to transfer text messages from iPhone 6 to your computer. Here you will find a quick way to transfer text messages from iPhone 6 to computer.
The Tool You Will Need
1. An iPhone 6 with text messages you want to transfer;
2. A USB cable;
3. A PC/Mac computer;
4. An iPhone content manager-AnyTrans.
Step 1. Download and install AnyTrans on your computer.
Step 2. Launch AnyTrans, connect your iPhone 6 or 6 Plus to the computer. On the homepage of AnyTrans, click "Messages".
Step 3. Choose the messages you want to transfer, click the To PC button on the tip-right to start transferring.
Resource from:
How to Transfer Text Messages from iPhone 6 Plus to Computer
on Dec 26, 2014 • Apple iPhone 6
How do I record on the TOMY Sweet Messages Photobug
Jan 17, 2015 • Toys
Need to retrieve my messages on my GE home phone that had messages from my son who passed in June of 09. PLEASE help me. Model # 29893GE1B. PLEASE, Hearing his voice helps me throught the grieving process.
Ms. - I'm so sorry for your loss.
The least difficult and technical way to retrieve the messages to save would be to buy a digital voice recorder as shown here on Amazon.com
Click Here
or any larger store that sells consumer electronics. There's no need for expensive as spending more money would not get you any better quality recordings of your son's messages. The only feature you require is that the device have a USB connection so you could connect it to your PC and save the recordings to your PC hard drive.
Before you start recording messages be aware that because the messages are digital you can replay them as many times as you need to to get the right quality withou causing them any damage.
To start saving the messages you would place the microphone of the digital recorder over the phones speaker on the left side of the phone at about a distance of 4 to 6" to start. The manual for the digital recorder probably would give you specific advice about this.
The recorder works like a minauture tape recorder. To start recording messages press the RECORD button on the digital recorder, a few seconds later hit the phones PLAY/STOP button to begin the message. When the message is finished hit the phones PLAY/STOP button and then the stop button on the recorder. You've recorded the first message. It's a good idea to rewind the recorded message and play it to make sure the quality is adequate (it should not be much different from the original in quality) If it's OK, move on, recording the messages one by one until you are finished.
To save the messages permanently you would plug the recorder into a USB port on your computer and copy the files to the hard drive. As a precaution, please copy the files over to another medium also, either burning them to a CD or DVD or copying them to a USB thumb drive.
I hope this has been helpful. I hope your healing has begun.
Peace, Mikeywaf
3helpful
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
1726 does not record messages
System will not record messages
When memory is full, saved messages must be deleted before new messages can be recorded.
If RO (announce only) is selected, no messages will be recorded.
Says machine is full, but there are no messages on the machine
make sure you retrieve all messages . I mean you may have 0 new messages, but you have lots of old messages ,it may full too.
Otherwise, delete all message, try to record incoming message or record your personal greating. Make sure the record function work, record chip works as well.
2helpful
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
message
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
