Stoves 720EF Electric Double Oven Logo
W
William osborne Posted on Jan 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
<!-- from fixya rte -->What size in litres are the 2ovens? - Stoves 720EF Electric Double Oven
Mikey
Level 3:
Top Expert:
  • Master 6,904 Answers
  • Posted on Jan 17, 2015
 Mikey
Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1621525
Points
26106
Hi, for the top oven:
Actual capacity 39 litres, Usable capacity 35 litres.
for bottom oven:
Actual capacity 59 litres, Usable capacity 50 litres.
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
What size wire do I need for a ge profile 27"
Well, 6800W/240V = 28.33 amps, call it 30. Minimum AWG wire size 10ga., if you're running it over about 20' go up to a 8ga. to be sure your oven is fed adequately.
lp
Jan 01, 2011 • GE Ovens
1helpful
The door handle is broken where it screws to the oven door. The threads are stripped. How can the problem be fixed?
there are a number of ways...first, if you have enough room, you can try to drill and rethread the next screw size....if you dont have the room, then there is a kit called a helithread...it consists of different drill sizes and little inserts that allow you to repair the threads that have stripped out...these kits are available at auto parts stores....if you wish to drill and re-tap the threads, then your local hardware store should be able to help you with the drill and tap sizes for the next screw size
Dec 08, 2010 • Ovens
3helpful
Hi, where can I get an owners manual for a Lumina 30 litre convection microwave model #D90N30ASLR-T4/H purchased from Aldi?
Try:
http://www.tempoaustralia.com.au/images/stories/instructionmanuals/d90n30aslr-t4_instruction_manual_ver.4.pdf
Nov 18, 2010 • Ovens
Error E# and F1
Hello,the error codes E3 and F1 means Wiring harness cavity size does not match previous stored valued
SOLUTION:The "Cavity Size Select"jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for.
Thanks
Gas connection on bottom of oven does not accept std 1/2'' flex hose?
all gas connections are flair fittings if the 1/2 inch is to large a 3/8 inch is the mext size down. if the 1/2 is too small the next size up is 5/8
2answers
How many litres is the 650W national NE 8070 microwave
I havent solved the problem and I dont want to pay to find out the litreage of the oven.
Sep 02, 2009 • Ovens
2answers
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
