Replaced ink cartridge with Office Depot brand ink cartridges
You didn't use the HP printer cartridges? I know they are expensive. but the quality is worth it . I trust not a cheaper ink in a quality printer. You may need to check this HP url
Printer Prints Blank Page or Does Not Print Black or Color Ink for the HP...
When you get to Solution four: Use an automated tool to clean the printhead a helpful tip is to repeat the printhead cleaning up to 4 times .
Testimonial: "Thank you NiteFalll Problem solved! Day saved! You're my Hero!!"
Usually this is a simple solution, check each color cartridge to see if they are where they are suppose to be this usually cause by having the magenta cartridge or cyan color in the wrong place , reposition all color cartridges and perform a head cleanup it may take a few prints to get the colors right as it had ink in the print head mixed up but get but eventually it will get fixed!
SOURCE: "remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
SOURCE: hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
SOURCE: installing ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00217748&lc=en&dlc=en&cc=us&lang=en&rule=7197&product=391182
this link will help you for replacing ink..cartidge
SOURCE: where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
