We unplugged it to try and see the error but can't recreate it
SOURCE: Whirlpool Duet won't run
Ok... so I had the problem, tried a couple of things... nada. So I stared at it and thought for a minute and looked at all the buttons. I looked a the button to the way right that said something like hold down for 3 seconds. I did it and all of a suuden it worked. I hope this helps you guys out.
SOURCE: whirlpool duet sport frontloader washer, door wont open, locked up.
Not a problem glad we could help.
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
SOURCE: whirlpool duet washer ghw9250mw1 door won't close ...
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
The F21 error code indicates a long drain time on this type of washer. The door will not unlock if the washer control detects that water is still in the tub. To manually unlock the washer door, take these steps:
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the filter out and clean it You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Here is a video to show you how it is done.
Hi Melissa Lombardo, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
