Question about Westinghouse SK-32H240S Television
I have a Westinghouse SK-32H240S, the picture is b&w. I've tried a hard reset and messing with the settings and nothing works. Is there anything else I could try?
    Master:
  • 530 Answers
Jestine Yong sells book on how to repair tv's like this google his name
Posted on Jan 18, 2015
6ya staff
SOURCE:
OT Bobby
  • 105 Answers
SOURCE: Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
Posted on May 18, 2009
Anonymous
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
Anonymous
SOURCE: SK-32H240S Gets past the "W" then goes black, with sound.
one of your transformers probably blew. had same problem with mine so took it apart and saw the problem. did some research. Darfon makes the power board and you have to buy the whole board not just the transformer. could cost you around 200 dollars. best bet is to call a local tv repair company and see if the have spare transformers for that lcd.
Posted on Jul 09, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: I HAVE A WESTINGHOUSE HD TV 23
Look for Bad capacitors on power supply board they will be vented or swollen on top 220uf 10v 330uf 1000uf 16v
Posted on Mar 18, 2010
westytech
vidal chavez
  • 120 Answers
SOURCE: I have a westinghouse sk-32h240s power light is on
Hello, it seems like your LIPS board has gone out. This board has two parts to it, one is the power side which is still working (you still have power and sound), and the second part is the inverter side. This side of the board is responsible for powering on and off the backlight. When this goes out your unit is still functional with the exception that you cannot see the screen. The repair is easy if you are at least a bit technical. You will need to contact Westinghouse at 1800-701-0680 to order the LIPS board, once you have that you will need to open the unit, the LIPS board is immediately visible, you remove the part and replace it with the new one and your TV is now functional. You can send me a quick email at westytech@wde.com if you need any sort of assistance. Please rate my help on this site.
Posted on Apr 23, 2010
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Aug 03, 2012 | Westinghouse SK-32H240S Television
What's the vesa pattern for westinghouse sk32h240s tv???
The SK-32H240S has two sets of mounting holes 75mm x 75mm VESA or 100mm x 100mm VESA mounts.
I hope this helps. The manual is available here: http://www.retrevo.com/support/Westinghouse-SK-32H240S-TVs-manual/id/2727ag925/t/2/ . You will need to enter a code to download the pdf.
May 19, 2011 | Westinghouse SK-32H240S Television
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Westinghouse SK-32H240S Television
Picture goes off sound stays on
Hi
Yes the problem has been solved. finally. The information on your web site was correct but the replacement board that I needed was no longer available. I ended up taking it to the local repair shop and he "worked on the board" that was messed up. Cost about the same as a new board would have, if I could have gotten one. Thanks for the great web site.
Dec 30, 2009 | Westinghouse SK-32H240S Television
When turning, on picture come up for 1/2 sec then goes plank,
My Westinghouse SK-32H240S television fails showing picture. Only sound can we hear but no picture.
Jun 02, 2009 | Westinghouse SK-32H240S Television
May 18, 2009 | Westinghouse SK-32H240S Television
Mar 28, 2009 | Westinghouse SK-32H240S Television
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
