Question about Godox PB820 PROPAC Power Pack
Where do I find the AC Charger adapter for a Godox PB820S Propac. I have look online and can not find the charger for this battery pack.
I have looked online in multiple stores to find the AC Charger. And still have not been able to find one. The battery pack is the Godox Propac PB820s Thank You!
  • bhargav Dec 06, 2017
    it is easily available on ebayhttps://www.ebay.com/itm/AC-Power-Charge...
    New Friend:
  • 23 Answers
If you still have the 12V car adapter it ships with, you can buy a 12V supply with a cigarette lighter connector and use that .
You could try contacting their main distributor who lists the complete device :http://www.lightinthebox.com/godox-pb820-backup-external-battery-pack-for-speedlite-vsp-136265_p995394.html , but does not list the charger alone.
Failing the distributor, try contacting the factory. They offer direct contact for support (godox@godox.com),including skype chat (GODOX@hotmail.com for MSN/skype).
Adorama sells the "Flashpoint" series of devices which seem to be relabeled versions of Godox products, but only sell the 960 larger power pack not the 820.
I read that the 820 DIN cable connector is compatible with Quantum cables. That *might* mean that one of the Quantum chargers *might* work for you, as those use a DIN connector for some of the rechargeable Quantum batteries. I once adapted a wall adapter for charging a Quantum battery pack and used a DIN connector. Unfortunately the Quantum chargers are expensive and there are a number of different models,so it may be difficult to figure out what will work for yo.
Posted on Feb 06, 2015
6ya staff
SOURCE:
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
Apr 28, 2016 | Computers & Internet
Can not load
Same problem. I cannot load my PB820. I know it is not a problem of battery because I tested them. I know it is not a problem of charger (very easy to test, pin 2+ and 5- on the plug). So it is a problem with the electronic.
I am waiting for an answer of Godox.
I cannot find any electronic description of the electronic part - it would be very easy to change any part - but cannot do it blind...
Feb 07, 2014 | Godox PB820 PROPAC Power Pack
When I plug the unit into the AC charger I hear a
w+pnt0gwwvrvgaaaabjru5erkjggga=
I would check battery, it may not be good, If you need battery look online it will be less expensive than buying from mfg.
Oct 27, 2017 | Cobra Electronics Cobra Jumpstarter Air...
The Bacini Acoustica will not charge. It works only when the charger is plugged in. Could the battery be "dead"? If dead, what type do I need to replace?
It requires a 12V 7.2ah battery F1 terminal. Its located on the bottom of the tower just under the charger input. You need a phillips screwdriver to remove the cover plate which has 6 screws. If you own this Bacini Acoustica Tower Speaker, please publish the wall charger information found on the back of the charger. I need to replace that.
Aug 03, 2011 | Televison & Video
The battery for my camera does not charge when I put it in the charger. I have had the camera and charger for about a year without any problems until now. When I put the battery in the charger, the green...
Assuming the camera is working fine:
Probably the battery, but can't be certain without testing. They do wear out from use. New battery packs sell for a little over 20 bucks - a two pack for for $35 - you can likely fine them cheaper at a battery specialty store online. Do a google search on "battery NP-40" You could also search for a compatible charger, just in case :)
Jan 04, 2011 | HP PB360t Digital Camera
Battery charger
You can buy it to any electronic or computer shop nera you like Bestbuy , Radioshack or any other store just give them model of your device and they will be able to provide you that....
or
click on hyperlink:
buy replacement ac power power cord charger adapter KAWASAKI PVS-1080
Jun 13, 2009 | kawasaki PVS1080
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Dec 11, 2008 | Peg Perego 12 Volt Rechargeable Battery
Need battery charger
Nov 12, 2008 | kawasaki PVS1080
Charger
The light can come in a box with just the light alone (light with battery), single ac(light with ac cord and 1 charger), single dc(light with dc volt cigarette outlet and 1 charger), double (light, 1 ac, 1 dc cord, 2 chargers) pb charger...and so on. The sticker on the box that contains the UPC code should have the listed detail on what the box should contain. Still confused check out the website www.streamlight.com search the light you're looking for and check out the product part number list. Hope that helps ;)
Jul 21, 2008 | Stinger Streamlight 75000
Godox PB820 PROPAC Power Pack Logo
883 people viewed this question
Top Godox Cameras Experts
Ekse
Marvin
Marvin
Are you a Godox Camera Expert? Answer questions, earn points and help others
