Tablets & eReaders Logo
J
Jessica Posted on Jan 18, 2015
Factory reset dopo tablet 2aap6m7041 with a cracked screen and touchscreen does not work
How do I reset my 9" dopo tablet
Press to reset the tablet. Insert a paper clip or other small object with a narrow tip into this reset hole at its bottom.
25829542-zbf0iuqrbs3vw1pstdxvekqu-4-0.jpg Gopakumar Gopalan Google
2helpful
I purchased a dopo 10 in. tablet for my son and it is completely locked, i need help please, it just says to many pattern attempts, then goes to enter email info, yet kicks me back to the lock screen.
Hi J ....it sounds like you will need to do hard reset.this may be due to the latest app you installed or a failed update from google.
first... Switch off the tablet.....second hold the power button and volume up together for at least ten seconds....third let the tablet do what it does till you see the android robot with red triangle....wait....then input from the menu offered ....usually you will need to reset the tablet to factory install.this is a pain but in future disable auto updates if you can.. Tell it to let you manually install.once you have the tablet back sign into you google play account.that should remember your purchases and help you reinstall .unfortunately you will lose all the private info and pictures.for what it's worth if you do decide to make another pattern draw it on some paper and photograph on another device.please vote if this helps you.have a nice weekend.
How am i suppose to unlock my password on my tablet?
this is how its done in most android phone and tablets. hope this helps
My dopo tablet i can not figure how to reset it
follow this steps and fix it. God bless you
Touch the "Power" or "Unlock" button (depending on device) to unlock your device screen.
    • 2
Press the "Power" button to turn the device off.
    • 3
Press the "Power" button to turn your device back on.
2. Factory Reset o 4
Touch Menu, then touch Settings.
o 5
Touch Privacy or Storage, depending on your device.
o 6
Touch "Factory Data Reset." A warning message appears. Touch "Reset" to confirm your choice and reset your device.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
