Ive tried to settle that e5 code displayed
SOURCE: Carrier Programmable Thermostat - E5 Code
I "rebooted" the thermidistat by opening it up to disconnect it from it's power supply, waited 30 sec, and closed it up again. After a few seconds E5 went away and the indoor temp appeared. The A/C started up after about 5 minutes. It seems to be working normally.
SOURCE: error code E5, also how do you set the time on the remote control
Check the code in the diagnostics in the manual
SOURCE: I have a Chigo Mini Split KF-32GW/A. What is
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
1、Check whether two sets of plugs on the outlet end of
the motor have loosed from the socket of the
electric control board, insert it firmly when loosing.
2、Check whether the indoor motor has damaged, the
motor should be replaced when it is damaged
3、 Check whether the controllable silicon and other
components on the electric control board have
damaged, replace the controllable silicon or electric
control board when they are damaged.
SOURCE: I have a Carrier Aircon.
E5 Outdoor activation of compressor over heatprotection or motor lock
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
Warning :
Do not enter any wrong unlock codes on your Nokia E5 mobile phones. If
you enter over a certain amount of wrong unlock codes on your Nokia E5
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your Nokia E5 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E5.
3 - Compose #pw+CODE+1#.
4 - The Nokia E5 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E5 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E5
Each Nokia E5 mobile phone has an unique unlock
code. You can buy the unique unlock code for your Nokia E5 mobile phone
using the form above.
The indoor to outdoor connection wire is loose better remove the connector and direct all connection if it is still error other option is the outdoor board is defective.
