Amazon Kindle Fire HDX 7 inch Tablet with 16GB Memory Logo
Gloria Person Posted on Jan 19, 2015
How do I fix my broken screen on my Kindle fire hdx with a frozen screen.
smeyer418
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 31 Answers
  • Posted on Feb 15, 2015
smeyer418
Contributor
Level 1:
New Friend:
Cheetah:
Answers
31
Questions
0
Helped
5708
Points
68
CONTACT AMAZON CUSTOMER SERVICE. I hope its under a warranty/service contract. Replacing a broken screen off coverage is expensive. If the screen under it is frozen its likely the dropping caused more problems than just the broken screen.
Amazon com Online Shopping for Electronics Apparel Computers Books DVDs...
3 Related Answers
GeoffW1
Geoffrey White
  • 3965 Answers
  • Posted on Dec 18, 2014
SOURCE: how to change a battary on a kindle fire HDX
There is no battery lid, the back must be removed
https://www.ifixit.com/Guide/Kindle+Fire+Battery+Replacement/7741
https://www.youtube.com/watch?v=WpffS2jN5Qo
greno1
  • 11 Answers
  • Posted on Dec 28, 2014
SOURCE: Our Kindle Fire HD is locked up, how can we unfreeze? we have already tried powering off
"Performing a hard reset on your Kindle Fire may resolve intermittent issues like a frozen screen, battery issues or trouble downloading content to your Kindle Fire. Allow your Kindle Fire to charge for approximately 30 minutes, then try the following steps.
To perform a hard reset on your Kindle Fire, press and hold the power button for 20 seconds and then release. After the device has completely turned off, press the power button to restart your Kindle Fire.
If your Kindle Fire is still unresponsive, try charging your Kindle Fire before trying to reset the device again." from here. Hope this helps, good luck.
protector606
  • 203 Answers
  • Posted on Jan 07, 2015
SOURCE: cannot get my kindle fire hdx to register to my account
You can use the help buttons on your kindle to contact Amazon directly for help registering your kindle. Amazon will contact you quickly and will have your account information available so they can assist you with your registration.
I have Amazon kindle 7" tablet that is frozen. It has no reset burton.
  1. Make sure the Kindle is turned ON. ...
  2. Press the Power button for at least 20 seconds. ...
  3. Wait for it to reboot - wait a minute or two. ...
  4. Your kindle should be back to a responsive state.
  5. You will have to go through the setup again and then synchronize to put your e-books and other data back on the device.
Kindle fire
James, You have to make sure the Kindle is charged, try holding the button longer, maybe even up to a minute, hopefully that will do it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." You can also do a search on google for this issue, seems there is a lot of info. on this problem.
Kindle Fire HD how to reset when locked up EpicReviewsTech CC
12 major Kindle Fire problems and how to fix them
My kindle won turn on Is it the battery Kindle Fire HD
HDX will not boot
It won't turn on all it says on the screen is kindle fire nothing else
Maybe the Kindle is frozen on that screen. The Kindle HDX User Guide suggests a hard reset by holding down the power button for 20 seconds before releasing it. That should shut the Kindle down. Be sure to not have the Kindle on a charger or hooked up to a USB cable during the hard reset. Next restart the Kindle. If that fails then charge the Kindle as you would normally do and when done detach the charger and USB cable and try another hard reset. If all fails go to www.amazon.com/kindlesupport.
Why does my kindle fire flicker and revert to random pages or page back to the beginning of a book?
Kindle Fire: 12 Common Problems and How to Fix Them ...
www.digitaltrends.com/mobile/kindle-fire-hd-problems/
Mar 6, 2013 - If you are experiencing some Kindle Fire HDX problems then you might just ... Try deregistering your Kindle Fire HD by swiping down from the top and tapping More > My .... by Simon Hill: Updated to add sound problems, screen flicker glitch, ... Lion Captures A Baby Baboon But Does The Last Thing You'd ...
Amazon.com: Customer Discussions: Screen Flicker on Fire
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 17, 2011 - The Fire's screen should not flicker; if it does, call Amazon CS and ... *update* i called about my flickering kindle fire. customer service was ... Kindle Fire HDX 7 inch - Screen ...
Dec 26, 2013
will kindle fire hurt my eyes?
Nov 1, 2011
More results from www.amazon.com
1helpful
I bought an amazon kindlw fire hdx 8.9, No manual !
Hope this helps...
  1. On your Kindle Fire, swipe down from the top of the screen and tap Settings.
  2. Tap Help, and then tap User Guide.
My kindlefire HDX is frozen and I can not reboot it. What can I do?
I have the same model and had not had that issue. None of the buttons work (hold each down for 10 seconds)
2answers
Frozen screen and now it won't turn off
If your kindle are frozen and won't turn off so, firstly reboot your kindle this is done by pressing the side button minimum 20 to 40 second and screen are blinking so, give the kindle about one minute to start backup.
What to do when Kindle Stuck on the Start screen
2answers
New kindle 3 . screen has frozen.
Amazon might help you with this because it is so new. However if you dropped it (etc.) and if HTC doesn't replace it for you, You can get the part at Kindle 3 Repair and there is a guide that shows you how to put in the part at Kindle Repair Guide.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
