A factory rest requires no previous user information.
Your tablet could not have been set up with HER information. It is probably asking for yours as the parent, as that is what i used to install apps bought for the tablet. from Kurio. Try the forgot password option using your email address. If that doesn't work contact Kurio support https://www.kurioworld.com/k/us/parents/support/contact?product=kurioWatch#device. They should be able to use the device serial number to locate your account information.
If you bought a second-hand iPhone/iPad stuck on the activation lock screen and don't know the previously used Apple ID and password, iMyFone iBypasser can help you activate iPhone/iPad without Apple ID. This excellent tool came out in 2020 and has helped many users who reset their own iPads without logging out the previously used Apple ID.
Put ipad back to default settings. Settings menu--This will erase everything on the iPad so you can start as a new user. It will erase original users saved info so you can input yours
You can try this: Go to Settings. Under Settings, scroll down to General. Click on that. Under General, scroll down to Reset. Click on that. That will open several lines of choices. The second one is "Erase all content and settings" - however, I have not ever tried this, so it's possible you will need the previous owner's Apple ID and password to complete this step. I would suspect you will, because Apple is very serious about security. So you may need to either contact the owner and get the ID and password, or your other option, as you said, is factory reset, which may be your only way out.
If iOS 7 is installed on the device then this is a built-in security measure against theft to prevent a thief from erasing content and using as new. You will need to get in touch with the original owners.
1. Boot iPad into recovery mode (You can find instructions online that explain this specifically) 2. Connect your iPad to your computer and open iTunes 3. Restore your iPad from previous backup
