You are first going to have to support the lower control arm that the spring is mounted to. Start by removing the wheel, then disconnect the lower control arm from the knuckle/hub assembly. This should be supported with the jack. Slowly lower the jack and by doing so this will free the spring. You may have to slightly pull it out from the spring seat pocket area. Place the new spring back in the seat and have a helper slowly raised the jack while you position the arm back into position.
