Question about 9080GLP6 Indicator Blown Fuse
My indicater fuse blows when ever i try to switch my indicaters or hazards on. What can be the problem?
It blows when i try to switch my indicater or hazards on. its for a 2004 model opel corsa sudan
    New Friend:
  • 88 Answers
Check the flasher relay.
Posted on Jan 20, 2015
6ya staff
SOURCE:
My hazard warning lights work fine but my indicaters wont flash
Check the indicator switch at the steering wheel!
Jan 10, 2015 | Cars & Trucks
Turn signal
check the individual indicater bulbs are all working ,actually look at each one not just the dash indicater light ,if all ok try the hazard switch if same happens the indicator relay needs changing if not the light/indicator switch will need replacing i would think good luck
Mar 19, 2014 | GMC Sierra Cars & Trucks
Hi wonderd if any one can help. i have a ford focus 2002 tddi estate the hazards arnt working but the indicaters are. i've changed the hazard switch for a new one and checked all the fuses in the
Look on the back of the fuse board ,for this you have to drop the fuse board as their are two fuses at the back and i know one is for the central locking ,the other ? Now when the hazard switch is disconnected the indicators shouldnt work but the only thing i can think of is the indicator unit is faulty ,do the hazards light the indicator lights up and they dont flash or is nothing happening?
Jan 24, 2013 | Ford Cars & Trucks
I have a problem with my hazard relay it is the second one that went on my hyosung gt250r in one week. I replaced it with an origenal part from hyosungsource but the relay starts clicking as soon as I...
You have a crossed wire someplace in your wireharness. go back to the dealer and make them change it - it should be under warranty if you bought it new.
Jan 06, 2012 | 2009 Hyosung GT 250
Indicater comes on but dosent flash santa fe 2005
Without actually looking at the vehicle's electrical system (fuses, wiring, flasher unit, hazard switch, multi-function switch (LH side of steering wheel), etc., it's difficult to say.
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations and procedures, etc
Aug 31, 2011 | 2004 Hyundai Santa Fe
Hazerds are working but indicaters are not
Keep in mind that the turn signal and the hazard signals are independent fuses/flashers; I suggtes check this fuse description (position 15 and 24, both 10AMP)...
Hope helps.
Dec 09, 2010 | 2002 Hyundai Santa Fe
I have a 2002 audi tt, the indicators are not working but the hazard lights are still working
check the fuse sounds like that has blown as hazards work on a relay indicaters are off a fuse
May 20, 2009 | 2002 Audi TT
Flashers stay on all time
Your factory alarm is sensing the low voltage, and it assumes someone is trying to tamper with the battery. If you can't reset your alarm shortly after the jumper leads are attached, your battery is more than likely unable to hold a charge. Have a local autoparts store check your battery with a load meter to see if it is "dead".
You will want to do this asap since your car is more than likely running off the alternator, and it will fail very quickly if you continue to drive the vehicle.
May 06, 2009 | 1996 BMW 318
Indicaters work as hazard lights
it may the back part of the hazard light switch down because it wasn't making the connection.
Jun 29, 2008 | 1988 Audi 80
9080GLP6 Indicator Blown Fuse Logo
65 people viewed this question
Top Square D Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Vitally Alcher
Are you a Square D Vehicle Part and Accessory Expert? Answer questions, earn points and help others
