Question about Ricoh Aficio 1515MF All-In-One Laser Printer
How do iremove error of code sc542(ricoh aficio 1515mf)
ERROR CODE SC542
    Master:
  • 587 Answers
This is an error for the fuser heat up..the temp is not being maintained or fluctuations.
try this -
press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change
enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.
turn machine off..
if the code disappears it could have been just a glitch
if not check the fuser to see if there is heat coming from it
the lamps will come on at the start up.
you can check this by putting a screw driver in the actuator slot to cheat the door switch
if you see the lamp come on then you may just have to clean off the thermistors ..
open the fuser up with the top screws and check that there isn't any build up of toner on thermistors..
Posted on Apr 13, 2015
  • Ricoh Expert
  • 422 Answers
Enter service mode, push in sequence (Clear modes button(yellow) 1 0 7 hold stop for 5 seconds) then power off, red switch. -Carl
Posted on Jan 20, 2015
    Dedicated:
    Visited the website for 20 consecutive days.
  • 819 Answers
542 Fusing temperature warm-up error (center)
The fusing temperature rises less than 7 degrees in 2 seconds, and this continues 5 times consecutively. The fusing temperature is not detected in 25 or 35 seconds. • Fusing thermistor defective or out of position • Fusing lamp open • Power supply board defective
This is the reason for the error code according to (printcopy.info) Might help you in some way, but not my area of expertise.
6ya staff
SOURCE:
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
My copier Ricoh Aficio 1515mf is writing call for service
You must specify the error, displayed in lcd, something like Sc322 or sc 548, etc..
That will tell the technician witch part to look,laser, fusion,optics etc. Penzance are right! Go on, post it!
Feb 13, 2015 | Ricoh Aficio 1515MF Digital Copier 15cpm....
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
the reset should be all you need...
reset link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 08, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Ricoh aficio 1515mf photoconductor reset
Found some information here:
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
Jun 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Mar 07, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
149 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
