It probably got stuck. to reset you must unplug it or press the
reset button for lock key... there should be a button of lock...
lock some button or just unplug it and wait some seconds.
Hello and welcome to the Fixya Community. Your Child Lock is activated.
When the child lock is activated, there will be a key symbol in the display and all the washing machine buttons will be disabled. To deactivate the child lock, press and hold the start button for three to five seconds. After this time you will hear an audible beep and the key symbol will disappear.
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock. Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Your washer is in the
"child lock" mode, hence it won't allow any program. Press the "menu" button until you
see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following
this the menu will close and it will default to program in the display. Once you see that in the display, press the
"select" button until "CHILD LOCK :OFF" appears in the
display. Finally by pressing the
start/pause button the key symbol should disappear - confirming you have
successfully exited the child lock program.
Look at the keyboard and find the button the shows the symbol for a key and a symbol for a light bulb. Press the FUNC button and then the key indicated above. The words key unlocked should appear in the display. Repeat the process to lock the keys again.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's...
1) Turn the program selector to any program as you would doing laundry. Add your items...
2) When you close the door the "start/pause" light flashes...
3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved.
4) Press the "select" button until the desired volume or "off" is reached/displayed.
5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed.
As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently. Means the machine is locked, for children. I
think if you do
it again it locks.
Pl rate me 'very helpful' for the free help, thanks
