Televison & Video Logo
S
Sven Sorensen Posted on Jan 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fix for 4 red blinking lights - standyby
Power cycle reset. 10min wait or longer. Changed power location Fault code ( 4 red blinking lights) indicates it may be power related issue. Tried to do a factory reset but cannot since it switches off - starts with green on light ..shows picture and then a click and 4 red blinking lights Sony Bravia KDL40S2010 parts seem to not be avialable
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Jan 22, 2015
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986685
Points
237762
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
1helpful
Diagnose Sony KDL-52EX700 6 red flash fault code
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://elektrotricks.blogspot.com/
Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
How do I fix my Sharp Aquos LC-42D62U TV?
My plasmatv 50pf9630a/37 indicator light is blinking on red i changed the power supply capacitors and still do the samething, what is it
1helpful
Sony Bravia showing 4 red blinks any idea what this means, fault?
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
I have a Panasonic TCP50G20. The TV was on for about 6 hours today. My daughter turned it off. She tried to turn it back on about 1 minute later, it wouldn't come on and now the power light just...
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
PDP 5030 blinking red light on monitor
Red light blinks 4 times
That sounds like a fault code coming from your Plasma. Some of them have alarms that go off when say it's overheating, Fans don't turn, the panel has sensed a crack in it. These are random as I don't have the fault code for that particular model. There is a reset sequence of buttons while you turn it on to reset the alarm. I would contact the manufacturer. to see what those fault codes mean. If something minor you can do the reset alarm and watch for a short 2-3 hrs. but will need to be taken in to be serviced. If you can reset it and turns on then you know your power supply is good.
NEC PLASMA SYNC 42MP2 STANDY BY MODE?
According to the manual for "POWER/STANDBY indicator is blinking in red":
  • "The temperature inside the main unit has become too high and has activated the protector."
  • "Promptly switch off the power of the main unit ans wait until the internal temperature drops."
  • "If the monitor becomes too hot, the overheat protector will be activated and the monitor will be turned off. If this happens, turn off the power to the monitor and unplug the power cord. If the room where the monitor is installed is particularly hot, move the monitor to a cooler location and wait for the monitor to cool for 60 minutes."
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
