I have a Nextbook Ares 10 A. The easiest way is to go to settings click on backup reset. U shud see the option to factory reset. Click it. It will ask if u r sure. Click yes. The device will shut down then a black screen comes up. You control this screen with volume buttons and power button. Using volume button scroll down to factory reset, click power button. It will ask r u sure. Click power button again. The factory reset will start. When it's done the same black screen will pop up. Use power button and click reboot. Ur done. Note:. This will not change the OS u r currently running, just all data, settings, app updates etc. Hope this helps.
if you let some of the tablets just sit and not being used they will auto shut off. you will have to go to screen settings and change the time on when to shut down
try closing your app open apps by clicking left hand button then should come up with your apps what you been on at bottom it should say close app it draining your battery if that does not work you may need a new battery
Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
Nextbooks do this when playing intensive games. They just aren't up to the demand on the CPU. Unless you were clearly warned about ths issue I'd say it is a warranty claim. Try to swap it for a games -capable brand.
The problem could be that you are pressing down the power button and the volume button at the same time when you shut down. That will cause an android tablet to reset itself. There may be an issue with the power shut off button.
You have to have headphones that are equipped for that device. I use Apple headphones for my Nextbook 7Premium Android device. It depends on what type of headphones you are using? You also have to push hard on the piece that goes in. Sometimes they don\'t go through so you won\'t be able to hear at all.
