I am testing about a hum noise in a Fender Strat. I have tested every possible junction of the grounds with a multimeter on ohms, and so far everything is connected. However, if I understand correctly, when you test resistance it only takes one good strand of wire to make a good reading. So how do you solve if a wire is corroding? (Preferably without the obvious -replace them all til it stops- method)
You are going to have to set that meter for ohms and not k ohm etc. When you check for resistance it should be close to 0. Check the wires one at a time and make sure that they are all pretty close to the same reading. Any one wire that is off from the others is suspect. Be advised that this could be a pickup issue or a signal wire that has floated to ground as opposed to an open ground.
Is there a level of tolerance that you would suggest as acceptable? Such as .4 Ohm ok but 1.0 ohm excessive.
The wires themsellves would have that amount of resistance. That amount is negligable. With this in mind have you tried another amp? Another thing to consider since you tested the wires is the power supply. If the capacitors in the filter circuit are bad, you would get a hum BUT you would hear it all the time whether a cord and jack are connected or not.
Visual inspection is best, but needs to be grounded to the output jack. also your amp might might be the cause also..
